reformat hard disc with ntfs file allocation
Brickinit
can anyone enlighten me on how to reformat a 20 gig.hard disk with a single partition. someone has attempted to install win xp on it but it locked out i have tried to format it using a win me start-up disc. it sees the drive but when you go to reformat c: it comes up with an error. any help would be appriciated
malc :confused:
ps. i don't have access to an xp start-up disc or cd-rom
RE: reformat hard disc with ntfs file allocation
if you have a windows 2000 disk you might be able to use that as it also deals with nsfs
good luck
> malc :confused:
Use fdisk and select delete no dos partion(depending on the fdisk) delete all partion then create a new partion it sets a single partion by default, reboot and format.
> malc :confused:
Brickinit
cheers Jan
spot on if i do enough of these i will remember these tips, but in the meantime i shall have to keep asking.what would we do without forums?
thanks again
malc
