problem with header function
I am having problems getting the header function to work properly. This works ok under my home linux apache config but not under f9. The code is:
header ("Location: http://cgi.tammclaughlin.force9.co.uk/cgi-bin/question_type.php?question=1&quizname=$quizname") or die ("Can't go to location ");
I just get the msg in the die function and no errors in my log files.
Any ideas?
1 REPLY
RE: problem with header function
> Any ideas?
Have you tried it without the or die, and are you sure that you haven't output any white space before calling the header function?
