phpbb2 problem
phpbb2 problem
My account has cgi and php enabled, im trying to install a pphbb2 forum on my webspace, the site is
http://www.smashuk.free-online.co.uk/forums/install/install.php
as you can see it is not processing the php code.
i have uploaded this to both my webspace and cgi webserver.
but when the page opens it appears that the cgi is not working.
Please help
phpbb2 problem
You need to install it to the CGI space so that the URL becomes
http://cgi.smashuk.free-online.co.uk/forums/install/install.php
The parser will then parse your code.
still no joy
Hi thanks for the reply, i have uploaded the forums to my cgi server and still recieve 404 error pages, i have also uploaded a simple index.php file in the root of my server, no matter what i upload to my cgi space i get 404 errors, please advise as i have been trying to get this working for over a week now.
phpbb2 problem
tbh im getting same results...
ive tried everything, and still dont work
phpbb2 problem
ok the first thing i would point out is that some users mistake the cgi-bin folder on the server for running php code, DO NOT put it in there, create a new directory in the root and upload everything in the phpBB2 folder to the new directory, then goto cgi.username.free-online.co.uk/newdirname/install/install.php this will then give u instructions on how to carry on.
Hope this helps
Platty
P.S. if ur still having trouble us the tutorial located at http://portal.free-online.net/central/forums/viewtopic.php?t=699
phpbb2 problem
mine isnt in the cgi-bin folder.. its in a seperate folder called forum
phpbb2 problem
You need to give a little more info m8, i know these may be stupid questions but it's the only way to get to the root of your problem.
1. have u activated the cgi webspace?
2. have you activated mysql?
3. are you uploading it to the cgi webspace?
4. can u give us a screenshot so we can see your directory structure?
5. what url are u typing in?
and anymore info will help, we should be able to get you there in the end, as i've just re-installed phpBB for about the 8th time, lol.
Platty
phpbb2 problem
1. Yes
2. Yes, and setup a DB
3. Im uploading to the cgi server, outside to the cgi-bin with index on root now.
4. http://www.ffsource.com/images/screen.gif
5. http://cgi.stiggauk-freeonline.co.uk & http://cgi.ffsource.com (unsure which one works as i have a domain directing to my web space..
Steven
ive upload using binary and chmod to 755
phpbb2 problem
phpbb2 problem
sorry some more questions, which version of phpbb u using? as this isn't the structure of the current version. and were'd u dload from? if it's not www.phpbb.com/ then don't use it.
Platty
phpbb2 problem
oh, this isnt phpbb
this is something different but similar
http://ldu.neocrome.net/
phpbb2 problem
lol, ok, at least were gettin closer..
have u been through this installation help page?
http://ldu.neocrome.net/page.php?id=1218
Platty
phpbb2 problem
aye,
completed all that to point 6.
"Open your home URL with a browser, select 'login', then register, to create your account."
tried both :
http://cgi.stiggauk.free-online.co.uk
Still not working
phpbb2 problem
ok just dloaded it, and if i get time 2night will install and see if i can figure out your problem m8, if not 2night will do 2morow.
Platty
phpbb2 problem
cheers.. its really annoying.. ive even tried a test php with a simple script and that doesnt even load..
im confused
