phpBB Session timeout
not sure if it is me but i have upgraded and installed a clean install of phpBB 2.0.8 and i am using this at present, i was wondering why the session time does not work or function, i had this same problem with 2.0.6 which was the last version which i used until i updated the changed files to 2.0.7. Just wondered if anyone else here has used this forum, and has had a simillar thing happen, or there is something i can do to check if it is something eithe ron the script or something on the database which i can check to see if this is enabled ok
