pc problems
pc problems
Got a message "Error himem . sys has detected unreliable XMS memory at address 012F3990 XMS Driver not installed Can anyone direct me to the correct help
Mycar
danep
RE: pc problems
Hi Mycar,
If it seems obvious it probably is. Memory faulty. Try reseating it, changing it, taking out one at a time etc, what op system you using, what PC specs?
Regards
Dane
> Mycar
espresso_mick
RE: pc problems
Go to this website:-
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q109845
Microsoft have a guide that explains what might be wrong and there is a troubleshooter to enable you to try and solve your problem.
Mick
