old device settings cleanup
Hi
I've read that every time I plug a USB device into a different port, it re-installs it, leaving the settings, including the drivers, in place for the previous port. Likewise, when I don't use a device (maybe ever again) the settings, drivers etc are left in place. I just can't see them, because the device isn't plugged in.
I know I'm simplifying, but I'm a simple person.Shockedops:
My question is, is there a utility that allows me to clean up all the detritus left by this process under Win XP?
slev
Hi
I use Ashampoo WinOptimizer Platinum Suite 2
Its a great little utility and is fairly cheap and does some nice clean jobs,
here is the description from their site,
Ashampoo WinOptimizer Platinum Suite2 is the great new successor to the hugely popular Ashampoo WinOptimizer Platinum Suite. With an all-new interface and many new features it gives you an unbeatable package of cleanup tools that will keep your Windows® installation lean, mean and running smoothly
Drive Cleaner
Registry Cleaner
Internet Cleaner
DLL Cleaner
Internet Tuner
StartUp Tuner
File Associator
File Wiper
File Encrypter & Decrypter
File Splitter & Joiner
PopUp Blocker
IP Spam Blocker
Easy Access to Windows® default functions
http://www.ashampoo.com/frontend/products/php/product.php?session_langid=2&currency_id=-1&idstring=1...
Hope this helps a touch
Kind Regards
Ian
Thanks I'll have a look Smiley
slev
By the way if you think about buying it make them an offer first :-))
I got it cheaper they have a deal on at the moment were you tell them what you would like to pay for the software !
http://www.makeusanoffer.us/Ashampoo/
Ian
... OK, so what did you offer them ? :shock:
