newsgroups
kenny
newsgroups
I use Outlook Express just for newsgroups (only) and `thebat` as my emailer everything used to work ok but the last week newsgroups has stopped working.
Anyhelp anyone I`ve tried to reset my setting for news only but it will not work. I noticed it stopped after this time out thing started last week, yet surfing and email software works OK
1 REPLY
newsgroups
Are you BB+ or Premier? Are you using the text.usenet.force9.net news server? news.force9.net will not work for me anymore but it is not a problem as I do not use binaries.
If BB+, you need to run a traceroute to the server and if it shows Homesurf in the hops, it needs to be referred to CS for resetting. Something to do with the capping not being compatible with the "safe surf" option in the portal.
Regards
Mark
