multiple Bulletin Boards on my CGI space
hi there,
is it possible to run multiple Bulletin Boards on my CGI space?
if yes, do I simply repeat the installation process, as I did for the first one and just create a new folder with new permissioning, or is there another way.
Thanks very much for help
regards Robby
I would say yes, but it obviously depends on which board you are using. I use YaBB and I would imagine that as you can edit the settings file to get the programme to create directories where you want them, then a minimal install in each directory name you want can call the rest of the files from your main "YaBB" folder.
Mark
thanks Mark, for your reply.
I use phpBB, and after I completely screwed up my first attempt with tempering with the bulletin board, I try to be a bit more careful this time.
the phpBB installation works as follows.
coopy ZIP file to CGI space, run installation which then creates a folder with all its files. Just permissioning and parameter setting.
So if I do exactly the same again, I would think there wont be a problem, OR?
Or a the two bulletin boards interfering with each other?
Problem is, I am new to all that php-stuff
Might just have a go. Worst case - wipe everything clean and reinstall
Robby
I would imagine that if you load the zip file to a new directory it will install itself there, although i'm not 100% and know nothing about php. The only problem I see is that the graphics and other stuff will take up a lot of your extra space. Perhaps if you unzipped the file yourself and only uploaded the files without the images? There must be a way to link to the images you havi in the other board in the admin section?
Regards
Mark
ncreu
Re: multiple Bulletin Boards on my CGI space
hi there,
Since phpBB2 uses the MySQL database I imagine you would need a separate database for a second copy.
It might make more sense to install something other than phpBB2 as the second board.
I don't believe that it's possible to have more than one table with the same name in a single MySQL database. Can't say for certain, but that would seem to be logical.
What happened when you tried to install the second board?
Richard
A second database would certainly work, but Force9 allows only one.
However, there's another solution. phpBB has a "table prefix" (the "Prefix for tables in database" option on the installation screen -- the default is "phpbb_") which may be used to differentiate the tables for several forums all sharing a single data base. Just make sure each forum instance uses a different table prefix value.
Thanks very much for all ideas and comments.
It worked!!
I copied the phpBB zip file into my CGI space again, and extracted file a second time.
I renamed the newly created phpBB2 folder to my second bulletin board name.
When installing phpBB via browser, I made sure that table prefixes got a new name, as you guys recommended.
Just finished installation as usual.
Have two BBs running on one database now.
Helps a lot and makes life much easier
Thanks again Robby
