male/female
male/female
You may not know that many non-living things have a gender.
For example:
Ziploc bags are Male. They are male because they hold everything in, but you
can see right through them.
Copiers are Female. They are female because once turned off, it takes a
while to warm them up again. It's an effective reproductive device if the
right buttons are pushed, but can wreak havoc if the wrong buttons are
pushed.
Tires are Male because they go bald and are often over-inflated.
Hot Air Balloons are Male because to get them to go anywhere, you have to
light a fire under them, and of course, there's the hot air part.
Sponges are Female because they're soft, squeezable and retain water.
The Web Page is Female because it's always getting hit on.
The Subway is Male because it uses the same old lines to pick people up.
The Hourglass is Female because over time, the weight shifts to the bottom.
A Hammer is Male because it hasn't changed much over the last 5000 years,
but it's handy to have around.
The Remote Control is Female. Yes, you thought it would be male. But
consider this -- it gives a man pleasure, he'd be lost without it, and while
he doesn't always know the right buttons to push, he keeps trying
