mailboxes
mailboxes
I am new to this server and I seem to have set up a new mailbox ok but cannot get into it.
RE: mailboxesReply Ivan
Hi margaret,
Do you know the email address of your new email box?
if you do then it should be possible to test this new emailbox & its address by sending yourself an email to this address. If you receive it all good and well, if not then you would have to investigate further or send a ticket to support at F9.
Ivan
ivan@cyteck.co.uk
If by not getting into it you mean connecting to it via the portal or by pop3 remember the user name will be your account name + the mail box name
So for example if I set up a bigal mailbox under my username (alphasigma) I would log in using: alphasigma+bigal
as the username via pop3 or using the webmail service using whatever password I set.
I remember having a similar problem about 3/1/2 years ago when I got my account here as the support pages never seemed to mention what user name to use apart from for the postmaster account.
RE: mailboxes
Hi Margaret,
I have tested your new mailbox and it works fine. Remember to use mlovell+marg and your password for this mailbox is in uppercase. If you have any further problems then please feel free to contact us.
Kind regards
Luke Horwath
Force9 Support
