log on difficulties
log on difficulties
Why is it that when I try to log on I get a message saying that I haven't a connection, but when I type the f9 address in the address bar I'm able to log on? any ideas?
1 REPLY
log on difficulties
Could be a couple of things to check.
1) Check the IE connection settings are set to never dial a connection
2) Are you using a Router or a modem?
If it's a router and you are using a DHCP option on the router, make sure that you have set the PC to use DHCP (Dynamic Host Configuration Protocol) to obtain the IP config it needs to rout through straight away.
Feel free to mail me directly if you need any help
