invision board
invision board
anyone successfully set this board up on a FOL cgi server.
i keep getting this error
mySQL Error: Access denied for user: 'platty@cobra.free-online.net' to database 'platty_fol'
i know my details are right, i copied them from the e-mail they sent
Any Ideas?? TIA
RE: invision board
> Any Ideas?? TIA
You're not specifying the MySQL hostname correctly. MySQL doesn't run on Cobra (the CGI server), it runs on one of two servers:
rumpus
humbug
Which one your account is created on will be shown in the email you received. If you're using the MySQL command-line, you can specify this by using the -h option, like this:
$mysql -u platty -p -h (humbug or rumpus) platty_fol
You'll then be prompted for your MySQL password (this is in the email).
If you're not using the command-line and it's part of a script (as I suspect it will be), simply input "rumpus" or "humbug" into the "MySQL Hostname" or "Database host" field in the setup script.
Hope this helps,
Mike
| Mike Grice Unmetered & ADSL solutions
| Technical Support for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
RE: invision board
thanks for ur quick reply, but i gave up on that and decided on phpbb instead (i was told it was easy, which it was) but now i can't get the board to send confirmation e-mails, i'm using relay.free-online.net
is that right?Huh
