internal examinations
just for the discussion:
What on earth is the point of an internal USB socket :?:
All the "5" port cards I've seen have 4 external and 1 internal ports :? What do you plug into the interanl port!!!
Any other examples of idiotic PC bits and pieces?
Well......................
I've got an internal/external 4 port hub that can either be plugged into an external port or mounted in a 3.5" drive bay and plugged into an internal port - which is how I've got it set up at the moment. I used to have a SD card reader with the same configuration.
Sorry
Rod
Fair point. I've never come across it, thus the question, and now I know Cheesy
