.htaccess
.htaccess
I have tried following the tutorial for password protecting a part of my site using .htaccess. I can manage to get the password prompt box but when I enter the password this is where the success ends! Has anyone managed to follow the tutorial and get the .htaccess process to work.
.htaccess
Yes, I have used it successfully.
.htaccess
Thanks for the reply and detective work in solving this one.
It appears that there is some confusion over the correct path that needs to be used for .htaccess / .hpasswd. The tutorial under usertools suggests having a hyphen between free and online whereas another post suggests using no hyphen. When I tried freeonline as opposed to free-online it worked and the password file was found.
Neil
