how many sites??
how many sites??
is it possible to have more than 1 website on your webspace
Thx anyone
how many sites??
Yes.
how many sites??
You can get your own domain and run it from your directory or you can create a directory under htdocs and place index.htm file in there and do it that way. So if you create a directory test you could then get it by going to
www.username.plus.com/test and your other site would be www.username.pluc.com
if you owned a domain you could point it in the portal to the test directory and that would give you
www.yourdomain.co.uk
