how do you set up a wifi network
can sombody please help me with setting up a home wifi network so that i can surf the net and share files on my laptop and please keep it in plain english. Ok this is what i have a laptop which is wifi ready and reconizes the router i am using, 1 adsl modem with built-in wireless router(belkin). 1 wireless usb network adaptor. Pc that also reconizes the router and is working on win xp with service pack 2 & laptop is working on win xp service pack 1. connections for the router are 1 adsl/rj11 & 4 lan connections. Pc has 1 connection for adsl modem and 1 network connection so please can someone help me with setting it up. Pc will be connected to the internet and the laptop will be using that connection (wireless)
thanx in advance
steve
slev
Hi
I have a similar setup at home myself ,
1 main pc connected to a linksys WAG54G via lan connection,
1 spare pc connected via wireless card,
1 laptop connected via wireless card,
I used winxp to config these for me via the home network setup solution ,
--> start / my network places
you can then select which options you want here eg
setup a home or small office network
or
setup a wireless network for home or office
Follow the onscreen prompts, and it is quicker to use a floppy when asked for to use on the other computers,
This will set all your computers up together , one thing you will need to do though to share files between each computer is to right click for instance your main hard drive on your main pc and goto properties / sharing and security and tick the box that says share this folder on the network,
You will need to do this with each computer that you want to share files with,
Hope this helps a little, each router is slightly different ,
Here is some more information that may help you,
http://portal.free-online.net/support/adsl/wireless_security.shtml
http://portal.free-online.net/support/adsl/networking_adsl.shtml
Kind Regards
Ian
Hi
One other piece of information not mentioned above:
When connecting your computers you either need to turn off the firewalls on each computer and rely on the built in modem one (if it has one), or manually allow each computer access to the other computers through the firewall(s)
I would suggest that you make sure that your router security is set up as well, you wouldn't want someone sitting in their car up the road accessing your files :!:
slev
Well spotted John Cheesy
I always forget that part as I use my router firewall and have software based firewalls on all my pc's.
I don't like winxp firewall it gives a false sence of security.
Kind Regards
Ian
slev
Steve
Have a look at the Tutorials and FAQs section of the forum, it contains some usefull information that will also help you with this.
http://portal.free-online.net/central/forums/viewforum.php?f=13
Regards
Ian
p.s have a look at http://setup.belkin.com/guide.html
this will help you more.
*edited to add belkin link *
