help with cron
help with cron
I am trying to set up cron to backup my cgi-bin but can't get it to work.
I have loaded AWScron.tab into root of cgi-bin, activated in telnet by crontab AWScron.tab, and checked it by crontab -l, but no go.
The file AWScron.tab is:-
MAILTO=cron@wrengco.f9.co.uk
10 * * * * /files/home2/wrengco/cgi-bin/AWSbackup/AWSbackup.pl (just for test purposes)
The email report keeps saying:-
/bin/sh: line 1: /files/home2/wrengco/cgi-bin/AWSbackup/AWSbackup.pl
: No such file or directory
but there is!
Any help appreciated (I assume that cron must be operational)
Dave
help with cron
cron is running.
This page is updated every minute, if you wish to check;
http://ccgi.chillypenguin.plus.com/lastcron.txt
Try adding a blank line to the end of your crontab.
Chilly
help with cron
Tried spaces, spare lines, changing all names to lowercase but it still comes up with same -
"...../bin/sh: line 1: /files/home2/wrengco/cgi-bin/awsbackup/awsbackup.pl
: No such file or directory....."
The mailto works ok.
Do permissions affect operation or have I not got the path correct? Any help greatly appreciated
Dave
help with cron
I think the problem here is so blindingly obvious that I can not see it!
Could I ask that you post up (or PM) me the first few line of your script.
Another suggestion would be to try it outside the cgi-bin directory.
Also I note that the script ends “pl” which is normal used for perl, but error on the first line references “/bin/sh”.
Chilly
help with cron
Tried most things but still getting same error message. Back to basics!
I am placing awscron.tab in root dir i.e. higher than cgi-bin with permission 750 - is that correct?
The awsbackup.pl is permed 750 - is that correct?
Is the cron file formatted correctly?
Someone please help
Dave
