help required with phpbb
I'm now trying the phpbb forum software, and have managed to install it on my cgi space, but i understood you could install this on your standard www.username.force9.co.uk pages and not have to install into cgi.username.force9.co.uk.
is this correct or must it go in the cgi space
regards
mike
Plusnet Staff
Plusnet Staff
As phpBB uses php it must go on the CGI server. You can create a frame or redirect on Homepages to point to cgi, but the pages must be on the CGI server.
Re: help required with phpbb
Have you given up on YaBB then or are you comparing?
Mark
You can also point www. at the cgi platform. Maybe you heard that once and thats what you meant?
