free-view TV
silvercliff
free-view TV
Hi Folks Smiley
Is there any one out there living in the BN10 post code area receiving these digital programs, via the freeview set top box :?:
Obliged Job
free-view TV
I'm not in that area, but best check http://www.freeview.co.uk/ to check your postcode.
Craigster
holdtight
free-view TV
The postcode checker is not at all reliable, when i checked mine it told me "not in my area"
a couple of weeks after i had to have my aerial replaced and got a digital one to future proof my signal, i asked the man who came to fit it to check for freeview availability he said no problem a good strong signal so i got the box and was away
if the postcode checker says your ok fine if it doesnt dont give up have your signal checked it only takes them a couple of minutes but you will need a digital aerial before you start
LiamM
free-view TV
Your best bet is to use this site - http://www.wolfbane.com/cgi-bin/tvd.exe?
The freeview postcode checker is, at best, crap. This site will tell you all your nearest digital transmitters, the type of aerial you need and the bearing you need to point your aerial in.
Takes a while to get your head around it, if you need help deciphering it, PM me your postcode and I'll look it up for you.
