form mail /cgi-bin/cgiemail
garydavis
I've recently enabled my account for cgi. My question is, do I have to use the f9 supplied form which only allows mail to be sent to a f9 email address. - I want to use something like standard /cgi-bin/cgiemail so that I can have the form mail a client. Is this possible with f9 and if so where do I point to ? - i.e. where is the 'cgiemail' or equiv script located ?
1 REPLY
You do not have to use the F9 supplied script for your forms if you have your own. If you use the F9 script, you are only able to send to email addresses with the F9 domain in them. I use a form from NMS (here http://nms-cgi.sourceforge.net/scripts.shtml). This allows you to customise the form and to remove any signs of an email address from your html.
HTH
Mark
