fax
fax
Is there a way to set up the XP fax software to send over my broadband connection. It seems to look for a standard 56K modem.
fax
I think it's meant to, i don't think it sends the fax over the web, i think that ur pc and 56k modem emulate a fax machine and dial directly to the receiving fax machine, not 100% sure though as I've never used it.
Platty
dbarrett
fax
Platty is spot on, When you dial the remote fax machine the combination of your PC and dial up modem acts as a Group 3 fax machine.
If you're very brave you can set up your modem to to accept ringing in and receive faxes too but it's a security hole you could drive a bus through!
Regards,
Dick
fax
Thanks. That's pretty much wht I thought. I'll have to consider putting a 56K modem back in, if i really want the functionality.
Receiving faxes is no problem, i use the FOL fax2emailservice so already have a separate fax number.
