e mail problem
e mail problem
hi, could you please help me . Trying to use outlook expess for e mail . Receiving ok .but smtp relay.force9.net does not work ,
e mail problem
Just checking, are you on a force9 connection when trying to send email? For security reasons this has to be the case.
e mail problem
I would check if the smtp server with f9 requires smtp authentication. By default, outlook express does not enable smtp authentication for its outbound connection to a mail server on port 25. You need to configure this within outlook and put in your server name, username and password.
Install something like ethereal and try sending a mail, then have a look at the TCP stream going to the mail server and see if there are any messages in there which relate to anything like authentication problems or disconnects.
e mail problem
check your firewall
