deny directory listing
I'm trying to block visitors viewing the contents of my directories without index.html files in them. I have used the .htaccess 'Options -Indexes' directive but it does not work :?
With the code in place, any request to my site just eternally downloads something unknown at 25% of my broadband capacity until I stop the browser.
Anyone managed to successfully block directory listings like this?
- Gareth
Re: deny directory listing
Don't you require a statement like:
    IndexIgnore *
There's some useful help at http://www.javascriptkit.com/howto/htaccess11.shtml, but perhaps this is what is causing confusion! It starts off by saying:
Typically a server is setup to prevent directory listing, but sometimes they are not. If not, become self-sufficient and fix it yourself:
IndexIgnore *
and later says:
And conversely, if your server is setup to prevent directory listing, but you want to list the directories by default, you could simply throw this into an htaccess file the directory you want displayed:
Options +Indexes
I think the second statement needs to be interpreted in the light of the first -- that typically a server is set up to prevent directory listing, so you might want to reverse that behaviour!
Thanks for your reply, task.
That does block the files being shown but still returns a directory list-style page. I am hoping to redirect the visitor to a custom Error 403 page.
According to http://httpd.apache.org/docs/mod/core.html#options this should be possible within the .htaccess file.
- Gareth
Well, I agree -- according to what I read there, I think your "Options -Indexes" should have worked!
I see, though, for particular directives to be obeyed in .htaccess files, certain parameters have to be set in an "AllowOverrides" statement in the main configuration file, and unless "AllowOverrides Options" is specified, Options directives in .htaccess files will be ignored. [Horrible sentence -- hope you can see what I'm getting at!]
But, looking through the directives, I saw you could do bit of a sneaky thing with the DirectoryIndex directive, which could be adapted to your purpose:
Note that the documents do not need to be relative to the directory;
    DirectoryIndex index.html index.txt /cgi-bin/index.pl
would cause the CGI script /cgi-bin/index.pl to be executed if neither index.html or index.txt existed in a directory.
So, if you had a page "/errors/err403verboten.html" which provided the message you wanted to send when someone attempted to access a directory with no index file, you could set up your DirectoryIndex as follows:
    DirectoryIndex index.html index.htm /errors/err403verboten.html
At least, I think that'd work!
Good theory. Just tested it and it works perfectly Cheesy
And now I can lay my beautifully crafted .htaccess file to sleep, thank you! F9 owe you one, task. You saved them a ticket Wink
- Gareth
