conexant adsl modem/router Q
has anybody tried using this modem/router for xbox live?
its not included in the "supported" router list from the xbox site so i wanna know if anybody has workarounds
since its not uPnP compliant, is there a way to make it uPnP thru firmware maybe or additional software...speaking of which, is there a uPnP software that'll make a non uPnP device defeat the limitations?
thank you very much in advance
RE: conexant adsl modem/router Q
I have user the MSI internal pci card ( uses the same chip set) with xbox live. Works like a treat.
Try setting up the Xbox's IP as DMZ under the routers Misc Config section under the Admin Privilege heading.
