caller display
caller display
i hope to have adsl up and running soon at the moment i have caller display on my telephone.does anyone know if i will still be able to use this service
RE: caller display
Yes, I, too, have caller display and it was unaffected by ADSL.
RE: caller display
> thankyou for your reply . force 9 tech support tried to tell me that it would not work when they done my line check. even though the adsl f a q on the force 9 web site tells you it will work ok.i think tech support my have a few wires crossed
RE: caller display
Sorry about that.
Yes, it will work. It works on mine.
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| Force9 Customer Support ........... for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
RE: caller display
i will let you all know how i get on with caller display once my adsl is activated
RE: caller display
> my adsl is now working . and caller display is working fine
