avat
avat
Hi I want to put a pic on using my profile, i want to put an avat on from "my documents " in my pc files the pic is called "avat1" in instructions it say put url, but if it is from my pc on my documents then how or what url do i use please thanks for any info Cheesy
Alecto
avat
Upload the picture to your webspace first using the website builder, then copy the URL from there.
avat
Don't forget to make sure its within the file size limits and pixel limitations otherwise you'll get a pm from the moderators (usually John) Smiley
Chris
avat
i have already done the size 80x60
thanks i will sort that out later
