What ever i try i allways get a gif of a paperclip.can't get it right.:bandit:
1 REPLY
chino
RE: attachments
Is this when you are using OE (outlook express)? As if it is you could be sending e-mails as a .txt file rather than a .html file. This is correct as long as you want the picture to appear as in the body of the message.
To change your setting to html is very easy...
If you need them just ask
cUnDaLl
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
