anyone had problams installing modem drivers on xp sp2
can anyone help i am trying to install modem drivers on windows xp pro sp2 it installs the drivers when i reboot i plug the modem in its syas processing than the icon below turns to yellow and it stays like that does anyone have any ideas
I had exactly the same problem when trying to install my modem.
Only on sp2
When i install it everything goes through fine the computer reboots then it pops up a message saying that it is configuring. It then seems to stop. After messing with the computer for a good 15mins i somehow kicked it into life by going into the add remove programs and adding / removing windows components.
It then gave me a green light on the modem.
Very strange. Also try and see if you have the latest install set / drivers for the modem.
Good luck
Sion
sion what windows programs did u remove
:shock: :shock:
What? Just at random?
