Zonealarm
Zonealarm
Sorry to go on about this
I have downloaded Zonealarm it seem to work fine I get a lot of alerts which surprises me I carnt believe they are all hackers.
Is it best to turn my XP firewall off
also does it interfere with Norton AV downloads
Thanks in advance Pam
RE: Zonealarm
Most of the alert will just be websites sending packets back to you.
Go to my
http://www.mwright.plus.com/drivec.htm
page and there are links on there were you can test your pc to see if its ok.
If you are using Zonealarm you dont realy need the XP fire wall but it does do a diffrent job to Zonealarm. Running to firewalls will slow you connection speed dramaticaly.
As long as you allow NAV it will download updates ok.
RE: Zonealarm
> Go to my
> drop xp fire wall.
speed not issue
