XP firewall
XP firewall
OK so I've installed XPSP2. I got a message suggesting that I should only run one firewall (I've got Zonealarm installed) Are there any problems with having both active?
firewalls
anyone :?:
XP firewall
I would disable the XP firewall. Running more than one software firewall can create conflicts, and more over, if a program fails to connect. You'll have two firewalls to investigate, not just one.
Stick to Zone Alarm but shutdown XP firewall. Cheesy
XP firewall
Thanks again gadgetboy.
Windows seems to have done that all by itself.
XP firewall
Check in control panel, windows firewall, check that it's disabled otherwise it will still be running in the background.
Aaron
XP firewall
I'd spotted that it was disabled already. I think when I installed SP2, it detected the Zone Alarm set-up and set the XP firewall to "off"
John Tongue
