Where to start
xpher
Where to start
OK I've read lots of bits about uploading php files, but I still don't get it.
My cgi is activated, but everytime I try to ftp to my space I can't even find it.
I've tried cgi.username.f9.com and crofters but all get is login incorrect. (Yes I did substitute username for my username.
Why have to do this with php anyway? Never known anything so daft, other providers I've used/use keep it so simple.
Where to start
I tend to use cgi.force9.net (which works for me), but, as you've pointed out, there are other names which can be used; crofters.force9.net should work as well.
I'd be interested how those other providers did things!
Where to start
Presumably using cgi.username.force9.co.uk works, considering thats what the actual URL is - for accessing in a web browser anyway.
Where to start
I don't know of any ISPs that offer PHP, but most webhosts that do let you have all the files on the one server.
xpher
Where to start
I just keep getting 'Log in incorrect'
(ps ClaraNet is one that you just upload php as normal)
Where to start
Have you changed your password? Failing that, contact support (ticket through link:Contact Us is probably best) and they may be able to get someone from networks who may be able to change the password for you.
xpher
Where to start
I am assuming that my password is the same as my normal login?
Where to start
Possibly, although they can be different on the CGI Platform, and also used to expire (and may still do, although mine never has) - http://portal.f9.net.uk/support/webspace/cgi_guide.shtml#20 has more information on Passwords Exprining.
