Whats the best bittorrent client
ggiannandrea
just upgraded to 2mb premium and can download from newsgroups at maximum speed
speed test below
17-05-2005 20:02:25 1908.8
but using bittorent client ( bit tornado) i'm still stuck at about 55 - 60 k
using windows xp
norton firewall
any help
If your using a router remember, you will need to forward the relivent ports and depending on your client this will vary. I personaly recommend bit tornado, nice and simple does all you need, im not bragging but whenever i jump on a torrent 95%of the time i get faster speeds than the people allready leeching and i tend to maintain that speed. The key thing to remember with bit torrent is you need to upload at a decent speed and make sure your connectable (thats what forwarding ports does).
Edit: also remember that you must not go above about 80% of your upload speed, due to the fact that this will effectively throttle your download speed.
ggiannandrea
not using a router
is there any tweaking i can do in "prefs" etc to increase my download ?
thanks for the reply
Nope just make sure your upload is between 13kbps and 22kbps.
When using the client i recommended what colour is the light in the top right of the window?
For Torrents: www.torrentspy.com or www.isohunt.com
For a Client: http://www.shareaza.com/
Happy Bit-Torrenting!!!!!!!! Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy
I prefer the edonkey/overnet network myself. Overnet provides serverless searches/downloads, and you just need the link rather than a file to start downloading something.
The new donkey client incorporates ed2k and overnet network, and even has a torrent plugin - havent tried it though.
deepfatfrier
Just a thought (it's been a while since I used BitTornado) - the client isn't limiting the download speed, is it (ie. it doesn't realise you're on 2MB now and is still accounting for 512k speeds). From my memory, I think BitTornado only has options to limit the upload speed, but then my memory isn't that good! Wink
Try uninstalling and reinstalling the client. Also, are you using WinXP SP2? Because I believe that limits the number of TCP connections, meaning you can't get connected to many peers...
ggiannandrea
thanks to all who replied but I've not got my bittorrent working at full speed (depends on where I download from) and I'm reaching of 240kbps :lol:
deepfatfrier
Glad to hear it, have a nice download Wink
they use same network as shareaza, most of them do except have different interfaces
congratz 2 u, also does anyone have good settings for Shareaza?? i can only usually get 50KBps when downloading stuff
Shareaza actually uses muliple networks including the bittorrent and edonkey2000 networks to download files. Shareaza does not actually have its own network, just builds on others.
The Overnet network is serverless, havent seen any other clients using it (please let me know if you have seen one), although emule is building in the Kad network which uses the same principals but they are not compatible.
Upping the max number of connections may help you.
3 alltogether
true. they do a good job of it though!
