Weblock CGI script and new default permissions.
Hi
I have tried to add weblock script to my site but am not sure if it will ever work.
It works by setting/adding .httacess files to each directory and i am having problems with it under the new CCGI system.
Will it ever work or do i need to change the permissions on my site.
Regards
See this link on the Plus.Net forums;
http://portal.plus.net/central/forums/viewtopic.php?t=30620
You can login using "guest" & "guest"
Sorry I would have quoted it but they have locked replies.
Chilly
Hi
Will try that...maybe I need wrrite permisions set also.
