Web Page Encryption
Marteknet
Web Page Encryption
Want to encrypt your web pages and have them still run in browsers ?
Try the online encrypter at www.martek-net.co.uk, it will handle HTML and JavaScript code.
The encryption method used is NOT a simple swap that always encrypts to the same result, the system used always encrypt's to a different result even in the same file.
for example "<h1>Testing Encryption</h1>" may encrypt to
"$l3~auAuW,D$T|byQQupT#^/S3^"
in one part of the encrypted file and
"£k4%ItfQ]Vj(TCvy[]uE],?/;-~"
in another part of the same file.
This of course will be entirely different in another files as no two files are encrypted using the same algorithm. There are other features as well. The file will fail to decrypt if the contents it transports are altered in any way.
There is a 14 day trail period on this I will be posting the full version very soon.
Link to Demo version is .http://cgi.martek-net.co.uk/php-bin/encripter/newencoder10.php
Its free to try. remember to back-up your files first.
Screen Dump of Encrypter
This was LOST when force9 lost users cgi script it will be back as soon as i code it again.
1 REPLY
Marteknet
Web Page Encryption
It's took a while as I had to re-write all the code for this utility.
An example of code encrypted by this can be seen working at http://www.petsallsorts.co.uk/testindex.html
Any feedback on this is helpful, prior to me publishing it for general use.
