WATCHOUT dodgy phone calls about
Hi all,
Just to let you know, if you recieve a call from a number starting with 0703
- the caller hangs up as soon as you answer. DON'T call them back.
If you do you will be on hold with a repeated message, and this is a premium rate number. (I know 2 crazy fools who called back and were left on hold for
ages)
from Julian
1 REPLY
RE: WATCHOUT dodgy phone calls about
It's not a premium rate number.
It's a 'find me anywhere' number, inother words a mobile or pager, although it is rather expensive.
Check this link for more info, also shows the operator so you can track it easily.
http://www.ukphoneinfo.com/cgi-bin-Phones/nng?GNG=0703
