Using Foriegn Keys with PHP Database
Hello, I now know how to insert data into databases and return results from a database. My dissertation involves me creating a PHP database and i know that i will probably be penalised if i use a flat file database. So what i want to do is create a database with 3 tables.
Product
Suggestions
Errors
The primary Key of Product will be an auto incrementing int(2), and i need to have this as a forieng key in the other two tables. Problem is in my PHPAdmin it says these features are disabled. when i creat eth etable i haven't noticed an option for selecting foriegn key. How do i do this, or am i best off writing the SQL create code myself and including a foriegn key line in the create statement and then trying to run this statement through the PHPadmin centre
thanks for any help
1 REPLY
mySQL (AFAIK) only does explicit foreign keys in one sort of table - and they aren't available on Force9.You can use the foreign key concept, just not explicitly as far as I know.
