Temporary Fix - Help needed! :)
Hello people,
Right, my site uses sessions and i have a perfectly working local version of the site and everything is hunky-dorey.... BUT f9's servers run an older version and it's not so happy anymore.
So, basically i need a bit of help with the php to find a temporary solution to the problem.
Facts:
a) It creates the session.
b) I dont believe that it records any data to the sesssion as the file sizes stay at 0 bytes.
I'm *trying* to write to the session thus:
eg:
$_SESSION['UserName'] = $UserName;
This works fine on my pc, so i assumed it would work here... but no... i dont reckon it does....
Also, when retrieving the info from the session....
echo "<P>UserName: " . $_SESSION['UserName'] . "</P>";
This returns nothing (but if it doesnt write anything to the session file what do i expect eh?!)
Any help is appreciated!
Liam
RE: Temporary Fix - Help needed! :)
Older versions of PHP used:
$HTTP_SESSION_VARS['varname']
to access session variables, not sure offhand what version F9 is running, although it's been mentioned in another thread. Anyway have a look in section "XCII. Session handling functions" of the PHP manual for more information
Cheers, but i'm afraid i couldnt get it to work.... i think i'll just wait till f9 have got off their arses and upgrade.... i may be waiting a while....
I am using sessions on the f9 crofters server at the moment. try this:
session_start();
session_id($sesh_id); <--Passed as a QueryString, the fist instance can be get from session_id();
$localselectedstyle = $selectedstyle;
session_unregister("selectedstyle"); <--removed the variable from the session.
session_register("selectedstyle"); <--registers it again.
You don't have to unregister it and register it again, you can just reference against it once you have started the session and specified the ID.
I hope this helps.
Cheers
(This relys on REGISTER_GLOBALS being turned on, and on the crofters server it is)
again, I hope helps,
Cheers
Chris.
