TOSHIBA 32' FLATSCREEN
I am thinking of buying a Toshiba 32" flatscreen
32zp18q. Has anyone else had any experience with this model. Good or badHuh
RE: TOSHIBA 32' FLATSCREEN
Very good TV although you may want to consider the Panasonic as well. Make sure whatever you get has 100mhz to reduce flicker not the 50mhz versions
Gary
> Gary
> Thanks for that. I've had a look at the Panasonic as well, I'm impressed. I have heard a few stories about'ghosting' on the 100mhz, but this problem was on early models and it seems to have been sorted.
Cheers. Peter
