Speed Testing
okmbok
Speed Testing
Can anyone put down the average figures they get when using the f9 Speed test utility.
I get figures around 460-470kbps
Is that good or bad??
:mrgreen:
PS can you guys also post results for pinging the following site aswell. Thanks
ns1.playnet.com
OKM
Speed Testing
I am receiving between 479- 560 on my connection. Dunno about pinging though, not sure what it is Shockedops:
Regards
Mark
Speed Testing
"ping <site>" at the command prompt.
Speed Testing
Okay, i've tried that and got lots of figures, which mean what please? I am assuming it is all related to spped in some way.
Cheers
Mark
Speed Testing
Yes - I think the OP wants you to post the output into the forum Smiley
Speed Testing
Pinging ns1.playnet.com [66.28.224.252] with 32 bytes of data:
Reply from 66.28.224.252: bytes=32 time=153ms TTL=52
Reply from 66.28.224.252: bytes=32 time=151ms TTL=52
Ping statistics for 66.28.224.252:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 151ms, Maximum = 153ms, Average = 151ms
Not sure what it means though!!
Mark
okmbok
what does it mean?
Its just a site for the MMOG WWIIONLINE
"Probably" the best sim online?? Wink
http://www5.playnet.com/bv/wwiiol/index.jsp
153ms is about what im getting.
Speed Testing
If you tracert it, all the delays seem to be outwith the Force9 network by the looks of things.
Speed Testing
475.7 - 500Kbit (before I upgraded)
957.10 - 1Mbit (now)
Reply from 66.28.224.252: bytes=32 time=133ms TTL=48
Reply from 66.28.224.252: bytes=32 time=132ms TTL=48
Reply from 66.28.224.252: bytes=32 time=136ms TTL=48
Minimum = 132ms, Maximum = 136ms, Average = 133ms
