Speed Test
Speed Test
For quite a while now when I do a speed test the result is crazy - today 51mb/sec, and that is not unusual.
Obviously the true speed is far less but why when it used to be ok has it gone like this - has anyone else had this problem.
Cheers
keith
1 REPLY
Trouble with test tool Ivan
Hello,
As you can see unfortunately the F9 speed tester tool is not as consistent nor reliable as it should (could) be, some times tests results in zero and at other times the decimal point is in the wrong place. To be fair the tool has been better recently but I dont relie on it, I suggest that you try one of the other testers that are available else where such as these below:-
http://www.adslguide.org.uk/tools/speedtest.asp
or
http://specials.zdnet.co.uk/misc/band-test/
Ivan
F9 FOL Forum Moderator
F9 Broadband Premier 2MB User
Your Forum Your Voice,Get Involved!
