Speed Test Returning 0kbps
Hi guys.
Tried running a speed test recently and it is coming back as 0kbps any ideas why this is? Could this be beacuse of firewall settings?
If i check my connections and the speed it is saying that I am connected at 10.0Mbps.
Any help will be greatly received
Adam
1 REPLY
When I used to use Norton I had to disable the firewall for 5 minutes. With XP firewall and IE listed in the 'exceptions' it works OK. Also try www.kbps.co.uk and use Custom option.
