Some more advice please!
trexalan
What the biggest harddrive you can get in a labtop.
Thing is, got a load of tunes i want to be mobile .
Whats gonna be half decent to sort this out, nothing else is gonna be on the labtop just tunes. needs to hold about 2500 12" singles, any ideas?
cheers phil.....
I would work this as follows:[list=1]
  • Decide on a codec and compression ratio / bit rate (it's the bit rate which will go towards determining the space required -- eg 128kbps)
  • Estimate an average length for each track 3mins? (=> 180s) 4 mins? (=>240s)
  • Given that you have estimated a total of 2500 tracks you can now estimate the space required to store them at the given compression.[/listShocked]So, assuming 2500 tracks of average length 240s at a bitrate of 128kbps:
    1 track of 240s at 128k bits/s => 31,457,280 bits => 3,932,160 bytes
    (I've assumed that 128k bits means 128 * 1024 bits -- not sure if this is true of audio formats, but it's a safer assumption than reckoning on 128 * 1000 bits)
    So if 1 track requires 3,932,160 bytes, 2500 tracks will require 9,830,400,000 bytes.
    Now, disk manufacturers use 1MB = 1,000,000 bytes and 1GB = 1,000,000,000 bytes because it makes their disks seem bigger.
    Therefore, a 10GB drive should hold your tracks, based on the assumptions made (average length 4 mins, 128kbps compression and 2500 tracks).
  • N/A
    I have seen laptops with 60 gig hard drives but I'm sure in another 6 months they'll be up to 180. Shortly after that you wont find one with less than a terabyte probably!
