Slow Connection - Friday (25-7-03) & Sat (26-7-03)
salis
Hi
I recently have been getting download speeds reaching a max of about 15kb/s. I normally get speeds of aroung 50 - 70kb/s
Anyone got this problem or know a reason for this. i have looked on the service status on the portal with no luck.
Any ideas?
mines been like this since install, although its most likely unrelated, let me know how you get on.
Yes But!!
Your comments are correct & Yes! I too have being experiencing terrible download speeds but I have a feeling that if you read the most recent announcements Re: BT ADSL scheduled work (i.e. work to BT's ADSL platform ) then some of the speed issue becomes clearer and after this maintinence work should I would expect things to be better.
Recent downloads have been utterly unacceptable especially when your paying for such a so called high speed high bandwidth service (NOT blaming F9 here either). Let hopes things do improve soon. Come on BT !!!
Ivan
Ianwild
Interesting... This isn't something that is being particualrily widely reported, and we are still 4th in the latest ADSLGuide Speed comparisons, so I would guess that this isn't somehting everyone is experiancing.
I think waiting until the MTU upgrades on BT's network is a good idea, but can't help thinking it might be worth looking into this some more.
Really, all I can do is point you to some resources that might help us
pin this down:
ADSLGuide (PlusNet) Discussion on MTU Values:
http://bbs.adslguide.org.uk/showthreaded.php?Cat=&Board=plusnet&Number=711232
Our Support Page about MTU Values:
http://www.force9.net/supportpages.html?bvIkeqvfDEk%3D
Both of the above may be negated shortly due to the changes being made as
we speak on BTs network. This might be worth a try though as a lot of
people who have seen speed problems on DSL have found a solution with
this.
You can also use the following links to provide us with more
consistent information about the problem:
ADSLGuide Speed Tester:
http://www.adslguide.org.uk/tools/speedtest.asp
Our Own Speed Tester:
http://speed-test.plus.net.uk/
The overall results from the speed testers should give us a decent
indication of the speeds your connection is capable of. This rules out
that you are simply experiencing slower speeds caused by the available
bandwidth at the other side of the link.
Regards,
Your current bandwidth reading is:
83.90kbps
which means you can download at 10.49 KB/sec. from our servers.
also
http://www.adslguide.org.uk/tools/speedchart.asp?id=4dbb8f90f6a5f5b0f74dbb8f90
:shock: Have you tried tweaking your settings?
did do, right now it's ok...
it went full speed the tuesday after i posted this so must have been something out of my control
(tested with different hardware but made no different)
