Setting up a domain - questions about www and mail
martinu
I've registered a domain with F9 but I want to check the way it's defined because there's a slight anomaly at present.
For ease of reference, let's suppose the domain is called mydomain.co.uk
In the "Domain hosting" section, it's defined as "Default" (rather than "Other - DNS") and I've pointed it to /htdocs/subdir/, which seems to access a sub directory of the www.<username>.f9.co.uk web space, as required. In fact the index.htm in that subdir is a redirection to my fp.<username>.f9.co.uk web space because that's where the site is hosted, but domains can't (so it seems) point directly to fp webspace.
A web address http://mydomain.co.uk works fine. However http://www.mydomain.co.uk points to somewhere else - the root of my ccgi.<username>.co.uk web space. Could it be a legacy of the way that F9 originally set up the domain: I notice that there are DNS records "www CNAME cshell.force9.net" and "www CNAME cshell.force9.net." (the latter with a dot after it). Should these DNS records be removed: is the setup saying than "mydomain.co.uk" goes to the subdir of the www space but the specific case "www.mydomain.co.uk" goes to cshell.force9.net which seems to be an alias for ccgi.<username>.force9.co.uk?
Next question: setting up email forwarding. I want email sent to <anything>@mydomain.co.uk to go to a non-Force9 email address. How is this achieved? Do I leave the "Mail setting" as "POP" or do I change it to "Other - DNS"? If I change it to DNS, what information should I supply? I presume I need to supply the mail server (the POP server?) that hosts the mail account, together with the mail account name. But in what form should this information be specified? I believe it's something to do with MX records.
