Setting up 3COM router to give access to my machine
Hello all,
I'm trying to setup my 3COM router (from the starter pack) to allow access to a connected machine from across the internet.
Has anyone done this with theirs? If so, any help would be gratefully received!
Colin
1 REPLY
RE: Setting up 3COM router to give access to my machineREPLY
> Hello all,
> Colin
Hi Colin,
From what you describe it sounds like what you want is to establish a VPN connection? I am also wondering is what you want to achieve is remote access? Have you looked at Terminal services or remote access (RAS),you may need to find out which specific ports on your router, you need to enable/open for specific services such as VPN connections or Terminal services or RAS,etc.
*If your still at a loss I wouldnt hesitate to get support or advise from 3Com.
Regards
Ivan
