Scart Leads
Scart Leads
Does anyone know if there is a scart lead that can connect into an aerial connection (that is a scart connection and a rounded standard aerial connection). I connected sky downstairs with a transmitter box and the receiver has a scart connection but one of my tv's does not have a scart connection only aerial connection.
1 REPLY
Scart Leads
You didn't state if the plug is pre-molded into the unit, or plugs in.
I am presuming plug-in. In which case, the following item numbers from Maplin should help.
VH89W - RF Modulator (convers the scart signal to RF)
You can use a standard scart sable with this, or use a RCA Phono adapter leads.
L16AJ - 1.5m Scart to RCA phono adapters
