Samsung E700 Data Cable
jabb0
I have got a Samsung E700, and i purchased a data cable for it off Ebay, but i cannot get it to work.
I have downloaded software from Samsung - this just crashes out, or says offline an will not connect.
I have downloaded software from Mobile Actions - this does nothing at all.
I am thinking that the driver maybe screwy, but really i have no idea what is going on.
The manufacturers website is http://tech.prolific.com.tw, but i cannot make head nor tail of what is going on there. can someone please help?
Has anyone else got a Samsung, with a datacable from Prolific which works, if so could you send me the drivers which you use, and perhaps a link to a site where the software that you use could be downloaded?
Cheers
1 REPLY
Brickinit
hi
try this link
http://www.mobiledia.com/forum/topic15811.html
it is for a mobile forum including samsung talk there is already some one on therewho has had simular problems to you and sorted it out with a link from there. i also had a problem with a data cable this morning and a quick flick through this forum told me where i was going wrong
