SSI on Webspace
SSI on Webspace
Do you allow server side Includes on your servers as I've been trying a few test pages with SSI in the pages with no luck.
If you don't allow it, will you in the future...
Cheers
G. :confused:
Simpsoid
RE: SSI on Webspace
Hi
I haven't checked but I was told:
"SSI is only available on the CGI server. Your files would have to be called .shtml"
Which sounds reasonable.
2Sheds
> Cheers
> G. :confused:
RE: SSI on Webspace
Thanks for that.
I'll try it once I get my CGI area activated... which is taking ages...
G.
> Hi
> 2Sheds
> > Cheers
> > G. :confused:
