SSI not working
SSI not working
Like fontaine posted in Running a CGI by loading, I am trying to run includes:
<!--#include virtual="cgi-bin/foo.cgi">
without success.
The cgi script itself is running fine, but the ssi (which works fine on the old server) refuses to play ball, putting the text of the script into the html page rather than the result.
Includes calling non-cgi content
<!--#include virtual="footer.html" -->
seem to work fine.
FWIW I'm on /files/home1
Sorted!
Tech support said I needed a .htaccess file, and told me to search the forums - but that wasn't entirely helpful.
So, for the benefit of anyone else with this problem - here's a step by step guide to making this work:
If you follow the advise of taskforce9 in this post:
http://portal.free-online.net/central/forums/viewtopic.php?t=701&highlight=htaccess+ssi+cgi
you will find out how to enable SSI using a .htaccess file containing the following code:
AddType text/html .shtml
AddHandler server-parsed .shtml
Options Indexes FollowSymLinks Includes
This turns on SSI, but it doesn't solve the cgi problem. For that, you'll need to add the line:
AddHandler cgi-script .cgi
so that the entire .htaccess file looks like this:
Hope that prevents anyone else having a stressful couple of days!
slev
SSI not working
Hi offbeat
Thanks for your work on this I am sure there will be some members who will need this information.
Kind Regards
Ian
