SQL syntax error although i dont know why
I get this error on screen "Failed during the insert of insert into Errors (Error_Solution) values ('the solution is n othing') where Error_Code = 6543562;"
when using the follwoing in my php page
mysql_db_query($DB_name, $sqlsol) or die("Failed during the insert of " . $sqlsol);
echo mysql_error($chan);
My sql statement looks like
$sqlsol="insert into Errors (Error_Solution) values ('" . $solution . "') where Error_Code = $_POST[id];";
The error_code field is an integer the error_solution is a mediumblob field. I have tried copying the insert statement that i output to the screen into my phpadmin page and get this
INSERT INTO Errors( Error_Solution )
VALUES (
WHERE Error_Code =6543562
MySQL said:
#1064 - You have an error in your SQL syntax near 'WHERE Error_Code =6543562' at line 3
i can't understand why its doing it as far as i know this is correct.
If anyone can offer me any advice that would be great. thanks
Marteknet
try this
$sqlsol="insert into 'Errors (Error_Solution)' values ('\" . $solution . \"') where Error_Code = $_POST[id];";
it excapes the "
not sure if this will work as i dont realy understand what the errors (error_solution) is doing in the database name field.
hope this helps.
Regards Peter
The (basic) format of INSERT commands is
INSERT INTO <table> [(fields, comma seperated)] VALUES (comma seperated list)
so
INERT INTO Errors (Error_Solution) VALUES ("This is an error") WHERE Error_Code = whatever
is invalid SQL.
If Error_Code whatever already exists, you want an UPDATE statement
UPDATE <table> SET field = value WHERE Error_Code = Whatever
(missing out the WHERE clause will set field=value globally in the table.
If it doesn't and you want to set Error_Code whatever you would do
INSERT INTO Errors (Error_Code, Error_Solution) VALUES (code, solution)
WHERE code and solution are the values or PHP variables.
salis
Re: SQL syntax error although i dont know why
You cant do an INSERT statement with a WHERE clause in it. You will need to use UPDATE
